wifiblues
Jul 22, 2021Luminary
outdoor satellite
hi - just purchased the RBK752 and I know that the RBS50Y has to be set up in Extender Mode - here is my question - When I go outdoors after the set up, will the satellite seamlessly carry the wifi s...
wifiblues
Jul 27, 2021Luminary
hi all,
help!
I am trying to switch the RBS50Y from Orbi mode to Extender mode. Read and followed the directions several times. No luck. It will not switch out. I recently upgraded to the RBK752 and it is up and running. Do you think that is the issue as to why the outdoor router will not switch? I am puzzled and cannot figure it out.
any thoughts?
- plemansJul 27, 2021Guru - Experienced User
whats actually happening?
Did you try factory resetting it and then switching it over?
- wifibluesJul 27, 2021Luminary
here is a description of what happens -
I plug it in - in the same room as the RBK752 router - push the sync button - push and release the powerbutton - the bottom lights up white then lights up blue - after i see the blue light - i release the sync - both lights are solid rather than pulsing - after i release the sync button, the bottom starts to try to sync to the router. now it is pulsing white - after a while it flashes magenta and stays magenta.
i have reset it a few times.
any suggestions?
After its went solid blue, it needs to be setup. its in extender mode and not orbi mode so it needs to be setup like a standard extender.
So if you do a wireless scan, you should see a netgear_ext name. Connect to that with a pc/laptop and go to www. mywifiext . net
