TheGrumpyGent
Jul 07, 2022Tutor
Partial Use of Insight?
Hello! I have an SXR80 and I'm using some settings that are not currently available within Insight (for example, setting the wifi security to "WPA2-Personal [AES] + WPA3-Personal"). I'd like to use Insight to remotely manage the router, but not have it impact the router's settings. Is it possible to use Insight without it making changes to the router, or does activating Insight require it also manage the firmware / settings?
Insight does have this capability to configure "WPA2-Personal [AES] + WPA3-Personal" aka. mix-mode e.g. with the WAC5xx and WAX6xx. looks like the recently added mix-mode to the Orbi Pro does not reflect this. Might be a simple oversight in the internal device/feature profiles. RaghuHR please investigate.
