Forthay
Apr 23, 2018Tutor
Pre Purchase Questions
Hi Folks,
I new to the forum so treat me gently!
I've been running a 6 disc BT Whole Home successfully for about a year. The latest firmware update has broken the system beyond repair for now. I'm looking for a replacement and although the Pro is for small business I think it might be a solution for my needs but I wanted to check some items I'm looking for are there when in AP mode
- through the Orbi UI you can see the list of clients connected to the Orbi
- clients connected to the upstream modem/router e.g. nas drive can be seen by devices connected via the orbi?
Hi Forthay,
Welcome to our community! :)
Yes, it will work on that setup. I suggest you to use the main admin network of the Orbi Pro in order for you to communicate with other devices.
- JohnC_VNETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Hi Forthay,
