PDA1
Aug 21, 2022Aspirant
Problem accessing DLNA server from satellite
Hello all, I have a very similar issue to the one describe in this thread: https://community.netgear.com/t5/Orbi/Problem-accessing-NAS-DLNA-from-the-satelite/m-p/1756357 My confiruration is: ...
CrimpOn
Aug 21, 2022Guru - Experienced User
Is there a switch in the network?
How is the satellite connected to the router? (Ethernet or WiFi)?
PDA1
No switch in the network.
Satellite is connected via WiFi.
- CrimpOnAug 21, 2022Guru - Experienced User
Does your system have a setting for WiFi MultiMedia?
- PDA1Aug 21, 2022Aspirant
Yes.
WMM is enabled for both 2.4GHz and 5GHz networks.
What about UpNP?
I have a dim memory of one reason Orbi's have "issues" with some unmanaged network switches is the vendor's implementation of IGMP Snooping. https://en.wikipedia.org/wiki/IGMP_snooping Notice the discussion under IGMP Querier. I found an Android app called UPnP Scanner that identifies the UpNP devices on the network and was able to find that an RBR50 router behaved differently when UpNP was enabled vs. disabled.
Sorry to flounder around.
