HugoGreefhorst's avatar
Jul 01, 2024
Problem finding IP adress
The 'house' Wifi works great, but on the guest network, it is impossible to log in. The response is: can not get IP adress. Do you know how to solve it?
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Would help to know more about the problem.
    • Is it only one device that cannot log into the Guest WiFi?
      (i.e. other devices are able to log in successfully. Have you tried other devices?)
    • What device is this that cannot get an IP address?
    • Is Access Control enabled on this system?
      (see page 84 of the User Manual)
      https://www.downloads.netgear.com/files/GDC/SXK50/SXK50_UM_EN.pdf
ProSupport for Business
