mharp705
Dec 13, 2023Tutor
Question on the Difference in Network using SRR60 and SRS60
Can someone help me find the difference between the Wifi/Wired Network characteristics of the SRR60 and SRS60? I have the SRR60 in my living room attached to the Verizon modem. I then have an SR...
- Dec 14, 2023
I finally figured it out, and its a bit silly. I had the Verizon Router still plugged in, and had the Orbi router plugged into that. Then it was relaying to the Satellite. Something in my head finally clicked, and I plugged the internet cable directly into the Orbi, which then got everything going on the same IP format (10.x.x.x). I guess when it says Router mode, that is my tip to use it as a router....
Thanks for your help though!
schumaku
Dec 13, 2023Guru - Experienced User
Looks like some kind of asymmetrical bridging - all fine on the satellite, but not ok on the router. BruceGuo any suggestion on how to troubleshoot?
- mharp705Dec 14, 2023Tutor
