Musicfan145
Dec 27, 2021Aspirant
Raspberry Pi 3B won't connect to wifi on SXR80
I have three different Raspberry Pi Model 3B devices that I cannot get to connect to my Orbi Pro SXR80 Wi-Fi system. They all will connect perfectly with a wired connection. When I scan for SSIDs, th...
schumaku
Dec 27, 2021Guru - Experienced User
The difference between the 3B and the 4B is the WiFi adapter - the 3B has "just" a 2.4GHz IEEE 802.11.b/g/n WiFi adapter, while the 3B+ and the 4B have dual band 2.4GHz and 5GHz IEEE 802.11.b/g/n/ac adapters. A possible idea is to disable the AX feature on the Orbi 2.4 GHz radio as a workaround for the poor/outdated driver 8-)
- plemansDec 27, 2021Guru - Experienced User
Another thing to check is try disabling the WPA3 security and just use wpa2
