Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
schumaku
Mar 06, 2024Guru - Experienced User
Unluckily, ScubaSteve007 's post was moved here from the Orbi WiFi 5 section to this thread by a moderator, by error without my original reply.
The answer to the post above was given before here before. Netgear has released a patch for the SXR80 and SXS80 before.
Chippy_boy
Mar 06, 2024Aspirant
Hi folks - hope someone can help?
I have an SXR80 and two SXS80 satellites. System is working fine and I am very happy with it.
However, I have a weird problem. I am primarily using Windows 11 and Edge browser and today I find I cannot access the Orbi login pages over my lan. At first I get the usual "Your connection isn't private" warning, but then when proceding, I get the following error:
Hmmm… can't reach this page
It looks like the webpage at https://192.168.55.51/ might be having issues or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLE
The strange thing is, I can still access the same IP/webpage using Firefox and it also works fine from my Mac with Safari! Also, I tried Chrome and that CANNOT access the Orbi either, with the same errors. So Safari and Firefox both work but both Chromium-based browsers do not!
I have tried the foilowing:
Cleared cache & cookies
ipconfig /flushdns
Tried Edge in Private Mode
Disabled all extensions
Does anyone have a clue what might be going on here? I am really stumped.
Thanks
- schumakuMar 06, 2024Guru - Experienced User
