BIG9MM
May 15, 2021Apprentice
I just paid $73.83 for 1 Captive Portal upgrade credit and can not use on the SXK80?
Do you guys know if the SXK80 has the Captive Portal upgrade? I just paid $ 73.83. I know the Netgear Orbi Pro SRK60 had it. On the purchase page they really should show which device allows yo...
schumaku
May 16, 2021Guru - Experienced User
Not available to my knowledge on the Orni Pro or the Orbi Pro WiFi 6 (yet, I guess). Not easy enough to find the appropriate list indeed, https://www.netgear.com/business/services/insight/advanced-wireless-features/ does refer to the common Insight AP WAC5xx and WAX610/610Y only (the 620 has not made it to the list).
This is a subject for the Ntgr marketing and documentation team YeZ
BIG9MM
May 16, 2021Apprentice
schumaku wrote:Not available to my knowledge on the Orni Pro or the Orbi Pro WiFi 6 (yet, I guess). Not easy enough to find the appropriate list indeed, https://www.netgear.com/business/services/insight/advanced-wireless-features/ does refer to the common Insight AP WAC5xx and WAX610/610Y only (the 620 has not made it to the list).
Thank you for the link!
- DaneAMay 17, 2021NETGEAR Employee Retired
Both of the Orbi Pro WiFi 5 and the Orbi Pro WiFi 6 devices does NOT support the Instant Captive Portal. schumaku already provided the reference website and the Orbi Pro devices are not included.
Also, on the article you have indicated on your initial post, if you click on the section that says "This article applies to:" it will show what NETGEAR devices supports the Instant Captive Portal. Check the image below as reference:
If ever you have any of the NETGEAR Business Access Points listed on the supported devices, you may use the Instant Captive Portal with it. Otherwise, you will need to open a support ticket with NETGEAR Support to ask for a refund.
DaneA
NETGEAR Community Team
- BIG9MMMay 17, 2021Apprentice
Why is it not on the "Captive Portal Subscriptions" page?
NetGear listed on the Captive Portal Subscriptions with :
"Features"
Advance captive portal
Full customizable splash page
Rich media support on the splash page
Social login, PayPal-enabled access
How hard would it be to put a list of devices that it works with on the Captive Portal Subscriptions page as I do not have time looking on other pages as I am paying on the Captive Portal Subscriptions page?
DaneA wrote:Both of the Orbi Pro WiFi 5 and the Orbi Pro WiFi 6 devices does NOT support the Instant Captive Portal. schumaku already provided the reference website and the Orbi Pro devices are not included.
DaneA
"Features"
- Advance captive portal
- Fully customizable splash page
- Rich media support on the splash page
- Social login, PayPal-enabled access
