davidcheok
Sep 18, 2019Apprentice
Orbi Pro Firmware update - V2.4.0.114
Just updated the firmware to the latest today. Nothing seems to have changed. 1) 2nd Wifi still gives a third open SSID (initially seems to work but 3rd open ssid appeared again after some time) 2...
- Sep 18, 2019
Did you see the issue on 2.3.5.108? then update FW to 2.4.0.114, still see the issue,
if you see the issue on 2.3.5.108, then update to 2.4.0.114, but config don't change after update, so the issue still happen on 2.4.0.114,
Please disable WiFi 2 and Enagle again on 2.4.0.114, it won't see the issue again,
We will fix it in next maintance release.
schumaku
Sep 18, 2019Guru - Experienced User
davidcheok wrote:FMI: https://community.openvpn.net/openvpn/wiki/BridgingAndRouting
That looks like a workaround for a workaround for a workaround.
No workaround - well, not for the Netgear side. These are two options available to configure the OpenVPN. The point is that not all OpenVPN clients (platforms) are supporting the direct bridging - iOS and non-rooted Android don't offer this for example. Regardess, even if the VPN does use a dedicated routed subnet for the connection, the LAN subnet should be reachable, too.
davidcheok wrote:The wireless gives me the opposite problem when i want a separate network for the guest ssid, it allocates ips from my private subnet.
Unless something basic was changed on the Orbi and specifically Orbi Pro model line, indeed the same IP subnet is used for all SSIDs. There is no VLAN isolation with routing for multiple subnetworks. Netgear does only deploy some L2 isolation for the guest network.
davidcheok
Its not a prudent policy to put unknown clients on your company network. Doing so simply invites potential hacks and with the large variation of malware out there infesting various o/ses, it would be a matter of time one propagates into an internal client. I would think it would be a simple job to create say separate private network to host these 'guests' especially since your guest ssid is unsecured. Dont know but thats just my logic.
- evan2Sep 18, 2019NETGEAR Expert
- davidcheokSep 19, 2019Apprentice
"Please disable WiFi 2 and Enagle again on 2.4.0.114, it won't see the issue again,
We will fix it in next maintance release."
Ok. Trying it now. Will update again if it fails.
Hahhaha. Disabling the wifi 2 and re-enabling has solved the 3rd ssid issue.
- davidcheokSep 19, 2019ApprenticeUpdate:
1) Wifi 2 3rd ssid unsecured resolved.
2) Client segregration on wireless 2 resolved
Still unresolved - vpn client on separate subnet
Thank you for the quick responses and help.
Hopefully vpn issue can be resolved in the next update (without us having to resort to alternative fixes).
Once again, thank you.
