TimC5
Aug 23, 2023Aspirant
Orbi Pro Wifi 6 SXK30 - Wifi looses WAN connection, wired ethernet continues have access to WAN
 Greetings,     We recently changed to Orbi Pro SXK30 setup. At the time there was a special going so we purchased to sets of the SXK30. We took the satellite from the second set and sync'd it into ou...
TimC5
Sep 04, 2023Aspirant
There is no ISP modem. It connects directly to the WAN port from our ISP by an outdoor rated and armoured 5E cable.
Our internet service is provided by a company that does point to point long range wifi connections.
The internet isn't the problem, any device on ethernet works fine, it's devices connected by wifi that are the issue.
We have the orbi pro router and 2 satellites, they are deployed in an open warehouse environment for 1 satellite and the router, the second satellite is hard wired by a 5E cable into the office space.
The router and satellite in the warehouse have line of sight and are approximately 12 meters (40 feet) apart.
BruceGuo
Sep 04, 2023NETGEAR Expert
when the issue happens, are you able to access Router GUI to download debug files and PM me?
- TimC5Sep 04, 2023AspirantThanks Bruce, yes I can do that. That said it's now making a liar out of me and hasn't done it again since I posted this, when it was happening once or twice a day. Hopefully it's resolved itself, however if it hasn't I'll pop the debug files over to you.
