wmarks79's avatar
Apr 14, 2021
Replaced SRR60 Orbi Pro not syncing to SRS60 Satelites and RBS50y
Hi-   The following setup has been working great all with current firmware version V2.6.2.200 SRR60 (3) SRS60 (1) RBS50 However a lightning surge took out the SRR60, which I had to ...
  • wmarks79's avatar
    wmarks79
    Apr 18, 2021
    Hi Dane-
    Welp, should have watched the tutorials online about "reseting" device. I didn't realize you have to press and hold for a little bit to get the green on/off LED to flash amber. Once I did that they all synced to new SRR60 Router.
    Understood about the serial number comment, my bad.
    The orbi devices were given to the company I work for, IT department. The department completed their testing and gave them to me. I've tried to register in the past and does not work on website. I've tried in the community, but no reponse. Is there someone I could contact?
    Thanks for your help,
    -Wyatt
ProSupport for Business
