Cfoote14's avatar
Cfoote14
RBS350 Satelites out of sync
Need help. Just installed new Orbi mesh system. Rbr 750 with two RBS350 satelites. Satelites are constantly showing out of sync for backhaul status. However connection is good and anything hardwired into them works great. Just seems like they are not pushing out a Wi-Fi signal. I’ve reset both Satelites and reset the router. One second it will show good backhaul status the next it’s out of sync.
  • Each satellite shows firmware 4.6.3.16 when I login to their website but does not show a firmware number in the Orbi app. Everything I’ve read seems like it’s a firmware issue. Do I need to update?
    • FURRYe38's avatar
      What FW version is on the RBR750?
      Is this system from the RBK650 series kit box?
      • Cfoote14's avatar
        Cfoote14
        System is from RBK653-100NAS
        FW on RBR750 is V4.6.14.3
