Andrew1918
Apr 24, 2022Aspirant
Setting up the SXR80 to Telstra NBN HFC I Australia
Hi I am trying to setup the SXR80 directly to the Arris CM8200 with Telstra HFC NBN. TPG show how to set it for other modem,but there are no option to set the Vlan priority .Can anyone show how to ...
- Jun 04, 2022
thank you
asked Telstra ,I don't need to set anything,
I turn off the modem for 10 mins ,turn it back on plug the orbi to it,it work.
DaneA
Jun 02, 2022NETGEAR Employee Retired
Be informed that there is no option to set a VLAN Priority in the SXR80.
Andrew1918 wrote:
TPG show how to set it for other modem,but there are no option to set the Vlan priority .Can anyone show how to do it?
From this part of your initial post, it seems that VLAN Priority is a setting that needs to be configured on the modem. Since TPG showed to you how to set VLAN Priority on their modem, I suggest you to contact Telstra HFC NBN and ask for assistance in setting VLAN priority to the Arris CM8200.
DaneA
NETGEAR Community Team
- Andrew1918Jun 04, 2022Aspirant
thank you
