Nakatomi2010's avatar
Nakatomi2010
Follower
Jul 03, 2022
Single Windows DHCP for all VLANs
I have a home network to which I have a five node Hyper-V cluster.  I'm upgrading from the Orbi RBR50 to the SXK80.  I use a Windows based DHCP server currently and was hoping to continue to do so after the replacement.
In looking over the settings on the SXK80 it doesn't look like I can tell
1 Reply
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    Nakatomi2010,
    Welcome to the community!
    You can try setting the SXK80 to AP mode if you plan to keep your Windows based DHCP server.
    You may refer to page 174 of the user manual here for the steps.
    JeraldM
    NETGEAR Community Team
ProSupport for Business
