iaeon
Mar 02, 2024Aspirant
SRK60 compatible satellites
Not sure I am in the right place - but I am trying to find out which Netgear Orbi satellites are compatible with an SRK60
Seems really difficult to find this information on the Netgear site.
Thanks
SRK60 is an SRR60 router with SRS60 satellites.
This should help:
Which Orbi Pro routers and satellites are compatible? - NETGEAR Support
- iaeonAspirant
Thanks for that reply - The compatibility chart did not come up in searches I did.
It seems this is an 'end of life' product and SRS60 is hard to find. RB50Y is compatible in extender mode only according to the chart. What does that mean in practical terms? A bit of a performance hit is OK so long as one can still move devices easily around the mesh network without having to select the access point once logged in.
Thanks for your help.
It means that devices will not roam seamlessly between access points.
i.e. in "Extender Mode", the RBS50Y behaves like any WiFi Extender from any brand. Not what you want.
Probably time to look for
- Refurbished products on Amazon
- eBay
There is probably an explanation for why this entire product line has gone End of Life, but it is not the sort of thing companies feel compelled to make public.
