Placzste
Jul 10, 2021Aspirant
Srk60 wifi signal poor
Purchased the SRK60 as a solution to my home network that has many devices connected. Gamers/streamers/echos/cameras. I have great signal and speed to the router and satellite, showing 950âs. when ...
schumaku
Jul 10, 2021Guru - Experienced User
Placzste wrote:
. I had the satellite hooked through Ethernet to my computer and had speeds at 925 which is great. Hooked computer to wifi and was one foot away from satellite but speeds only came in at 25.
When I understand you right, the satellite is connected wireless to the router and the difference from 925 Mb/s to 25 Mb/s is only related to using an Ethernet link to the satellite vs. using WiFi?
What WiFi client are we facing here on the computer? Link speed and effective throughput requires a decent WiFi adapter, up2date drivers, a 5 GHz link to the nearest satellite.
- PlaczsteJul 10, 2021Aspirant
Drivers are up to date. Screenshot below is what is listed under adapters. Sorry I am not super techie with thisđ Poor connection is over wifi. I can't choose 2.4 or 5 as they are the same ssid.
- schumakuJul 11, 2021Guru - Experienced User
What kind of wireless adapter is ii place?
The information of which device and band the adapter is connected would be avilable fro m Orbi - not from the client.
PS. We have a copy of the UM - probably wrong PDF uploaded?
- plemansJul 11, 2021Guru - Experienced User
Also, the SRK is the business class with 4x ssid's that you can use as well as you can set bandwidth controls for each ssid. (a percentage per ssid)
Did you seperate out devices on the ssid's? (used more than 1)
What speeds do you get hardwired into the satellites?
Are you testing over 2.4ghz or 5ghz? 2.4ghz is a slow network and sensitive to interferece. so check what band you're testing on
- PlaczsteJul 11, 2021AspirantSorry for the pdf. I know it is not driver as previous router had no issue getting higher download/upload.
I honestly did not pay attention to wether it was on 2.4 or 5G. When I initially set it up I had decent speed at 250âs download then the next day it was 25âs and never saw anything higher again.
I will setup the second wireless with separate ssidâs and re-test while connected to 5G.
What % would you recommend as to allotment of bandwidth. I currently have 4 TVs streaming and 2 desktops that kids use for gaming. (These I would guess should be on the 5G ssid). We have multiple Alexa devices (I assume 2.4 is fine for those) and of course cell phones and iPads. Normally have approximately 20 devices connected at a time.
