htgrimmi
Nov 28, 2024Guide
SRR 60 WiFi unstable when satellites connected.
I have a large house, 3700 sqft, and the router is located in the worst possible place. Upstairs, farthest corner away. Always had issues with WiFi in this house and went through a number of routers ...
Nov 28, 2024Guru - Experienced User
More doesn't always equal better with mesh systems.
What is your home made from? (internal walls, sheetrock, plaster lathe, tile, etc).
That is key as if the internal structure of your home does a good job blocking wifi, then using a wireless backhaul won't help much and can actually hind things.
You'd have been better off with your satellite in the middle of the home if it was wireless. The satellites still need a good signal to run off.
In terms of the more satellites, each home will be different. I've tried numerous combinations since mesh first came out with the initial placement of the router, number of satellites, locations of satellites, etc. Each home will be different so you need to try different locations, elevations, and number of satellites in the home to see what works better. Even sometimes a slight change in elevation (sitting on the floor versus on a counter) can make a difference if there's things in the walls like hvac that block signal. The hard part, is that each time a new technology (wireless BE) comes out, I have to rerun the testing to see what is going to work best.
So if you just placed the satellites and walked away, you left a lot of performance and instability on the table. You need to try different arrangements.
