htgrimmi
Nov 28, 2024Guide
SRR 60 WiFi unstable when satellites connected.
I have a large house, 3700 sqft, and the router is located in the worst possible place. Upstairs, farthest corner away. Always had issues with WiFi in this house and went through a number of routers ...
htgrimmi
Nov 28, 2024Guide
Thanks for the reply!
Home is stick and sheetrock and a funny layout. Think two square donuts stacked on top of each other.
Ideally, I'd put the router in the center of the house downstairs but I'd need to do a major CATV pull. The builder only CATV runs in a few of the bedrooms upstairs and the family & living rooms downstairs. Nothing centrally located.
I was going to upgrade the system but all is working fine with just the SRR60. Probably should have started out that way when I got it.
