WaldoMI
Jan 08, 2022Aspirant
SRR60 - Frequent random reboots
I purchased an SSR60 in late July 2020. It worked fine for more than a year. Shortly before I renewed my annual subscription, it became unreliable. It goes offline and I get Insight Alerts that it...
WaldoMI
Jan 09, 2022Aspirant
Many thanks for you help!!
HerbCSO
Feb 06, 2022Star
FWIW I had a similar issue recently and it turned out to be a faulty power supply. I swapped the router's and the satellite's power supplies and haven't had any more problems (RMA is on the way to get the faulty power brick replaced). Might be worth a try in your case as well.
