Skyflash
Mar 16, 2021Tutor
SRR60 internet connection locks up (no connection) intermittently
My Orbi Pro SRR60 has started intermittantly (about once or twice a day), suddently losing its connection on the WAN side and reporting no internet connection. It is plugged into a Nokia Telus F...
Wmb247
Mar 16, 2021Tutor
I am seeing the same issue with my SRR60 with the latest firmware as well... I am connecting to a Hiltron CODA-4582U Cable Modem/Router
- Wmb247Mar 16, 2021Tutor
Folllowing up on this, at this point the Router doesn't stay online for for more than 15-20 min at a time. At this point the Router and 3 satellites are basically useless to me.
- RaghuHRMar 16, 2021NETGEAR Expert
Hi Wmb247
Please send us the router and satellite debug log separately . We will check and update you.
Thanks,
Raghu
Where would you like me to upload the debug files?
I tried attaching them, but not having any luck
