ButterflyGirl
Dec 01, 2019Aspirant
SRR60 ORBI Pro router enable bandwidth per SSID
Greetings,
In the ORBI Pro setup, running firmware V2.4.2.106, under the Wireless 2 tab, there is a Bandwidth per SSDI section. There is a checkbox to turn it on and the 3 wireless networks shown on a slide control. When you turn this option on it gives you these defaults:
- Network 1 is set @ 35%
- Network 2 is set @ 35%
- Guest is 30%
However, I can not find a way to change the default %. The balloons above the slide showing the % does increase in size once it's selected, I can find no way to change the %s. Is it possible? If yes, how?
If you can't change the % does anyone know if enabling this would lock the SSID down to that %, even if the other networks were idle?
Does the enable bandwidth per SSID only work for downloads? I can't tell if the screen is saying download and there is another screen for uploads or just bandwidth metering on downloads.
Thanks!
Hi ButterflyGirl ,
Please refer to the user manual. http://www.downloads.netgear.com/files/GDC/SRK60/SRK60_UM_EN.pdf
We have implemented bandwidth management by prioritizing airtime based on SSID.
- JohnC_VNETGEAR Employee Retired
Hi ButterflyGirl,
Welcome to our community! :)
As of now, Rate limiting is still not supported on Orbi Pro. You may share this idea in our Ideas Exchange for Business board in order for our engineering team to consider this feature on the next firmware release. But I cannot guarantee it.
John
NETGEAR Community Team
- ButterflyGirlAspirant
John,
Thanks for the quick reply & my apologies for the late response. I've been without services on and off since mid-November as AT&T has been slowly updating equipment.
Anyway, reading between the lines of your response, the check box for limiting bandwidth per SSID has not been implemented. Therefore, it doesn't matter if the box is checked or unchecked. Correct?
I appreciate your help.
ButterflySoul
- BruceGuoNETGEAR Expert
Hi ButterflyGirl ,
