HerbCSO
Jan 26, 2022Star
SRR60 random reboots
So this is weird! I had a previous post on this topic, but that post is now gone. It simply disappeared. I have emails relating to it, but the post is inaccessible. Hmm... Anyway, I've been havin...
- Jan 27, 2022
The only other thing I'd try would be to downgrade to a firmware version prior to the one with issues and do the factory reset and reinstall.
If that still has issue, try swapping the SRR's power supply with one of the satellites. Maybe its having power supply issues.
Jan 26, 2022Guru - Experienced User
did you try a factory reset?
