vanishevo's avatar
Apr 18, 2017
Orbi - random reboots
Hi guys,
Bought an Orbi around two weeks ago, everything was going fine until one week ago when the random reboots started.
It most recently rebooted just 40 mins ago, as is reported within the show statistics screen. System Up Time 00:41:39
Has anyone else ran into this?
BTW, I'm running firmware V1.8.0.6
Thanks
Chris
  • A quick update.. after swapping out the unit, everything now works fine!
    Must have been a hardware issue.
    The RMA process was very straight forward here in Australia, a replacement unit was sent out along with a return con note.. all too easy!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello vanishevo
    How often is it rebooting?
    DarrenM
    • vanishevo's avatar
      vanishevo
      Guide
      Hi DarrenM,
      So far, around every second or third day. The current uptime is 1Day 16Hrs, which is just before I made the post.
      Some futher info around the setup: Router is in AP mode, patched into a brand new Telstra (an Australian Telco) supplied VDSL router.
      Thanks
      Chris
      • DarrenM's avatar
        DarrenM
        Hello vanishevo
        Have you noticed if you main router/modem is losing internet connection at the same times the orbi reboots?
        DarrenM
  • Hi Darren,
    It just rebooted itself again, was plugged directly into the wall.
    Have you heard of anything like this before? Sounds like I'll need to return it.
    Thanks
