HerbCSO
Jan 26, 2022Star
SRR60 random reboots
So this is weird! I had a previous post on this topic, but that post is now gone. It simply disappeared. I have emails relating to it, but the post is inaccessible. Hmm... Anyway, I've been havin...
- Jan 27, 2022
The only other thing I'd try would be to downgrade to a firmware version prior to the one with issues and do the factory reset and reinstall.
If that still has issue, try swapping the SRR's power supply with one of the satellites. Maybe its having power supply issues.
HerbCSO
Jan 26, 2022Star
Hello again! ;] Yes, I did, just now. Waiting to see the results of that one.
Sorry I had to start a new thread, no idea what happened to the old one.
HerbCSO
Jan 26, 2022Star
Ah, well, there we go, another reboot post-factory reset... :/
- plemansJan 27, 2022Guru - Experienced User
- HerbCSOJan 27, 2022Star
Regarding the firmware version, I've been on V2.7.0.122 since Oct 26 and the problems only started recently, so I don't think that is really the issue. Also I'd have to go back to V2.6.2.200 which is a bit old for my taste at this point, so I don't think I'll be doing that. However your idea about the power supply is a good one, so I think I'll try that, thanks!
- HerbCSOFeb 06, 2022StarSo just to close this out, turns out the power supply was indeed the issue. I swapped it with the satellite and haven't had any more issues since then. Have an RMA on the way to get a new one.
Thanks so much for your help!
