AllanA
May 31, 2022Guide
SRR60 Stopped working
Since the last update I've had two SRR60 routers, on two different sites, simply stop serving clients. The routers each power up but they no longer not poll, light up, to signal that they are working...
DaneA
Jun 01, 2022NETGEAR Employee Retired
Found out from the NETGEAR Support Team that you already have an ongoing support ticket regarding your concern as posted above. You may want to share the progress of your support ticket here.
DaneA
NETGEAR Community Team
AllanA
Jun 01, 2022Guide
So far no real progress was made. And, to make matters worse, a third router has failed. This happening when combined with no clue on how to correct whatever is causing this is very concerning since I've built two campuses WIFI platform on Orbi.
