oidee's avatar
oidee
SRR60 support Ethernet Unmanaged Switch x16 ports? and very high traffic?
my internet service plan, Fibre Optic Broadband. DL 1000MB, UL 1000MB, 300GB data traffic/per month.
I need install 5 room's. Each room 1xTV, 1xPrinter, 1xSatellite.
I need buy that Ethernet Unmanaged Switch x16 ports. "NETGEAR GS316 x16 port"
Each room fixed Wired, from Switch to Satellite.
(1) Is it possible that Orbi Pro Router, only use LAN1 port to switch, and that switch to that 15's fixed device.
and each room around 10 wifi device.
(2) If full loading around 10+3=13x5= Total 65 device's. That Orbi Pro Router can support very high traffic?
Cheers.
  • oidee,
    Orbi Pro can handle that kind of traffic. As the reference manual says on page 164, it can support up to 127 connections via wireless per frequency. Optimal is 40 clients per router or satellite.
    John
    NETGEAR Community Team
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    oidee,
    John
ProSupport for Business
