SonnyKS
Oct 19, 2019Tutor
SRR60 Wireless2 no internet
SRR60 with latest firmware downloaded. Set in AP mode with static IP on LAN. Wireless1 and Wireless2 enabled. Guest SSID disabled. Clients can connect to Wireless1 just fine and access internet...
Amidala
Oct 21, 2019NETGEAR Employee Retired
According to your description, I verified this version(2.4.0.114) and found no problems. Are you also in this version? Could you please send us the config file?
- RaghuHROct 21, 2019NETGEAR Expert
SonnyKS you upload into google drive or any such tool to upload debug logs and send via PM.
Thanks,
Raghu
- evan2Oct 24, 2019NETGEAR Expert
I see the issue using your config, because LAN IP is different from DHCP server,
I restore your config, OrbiPro br0 IP is static 192.168.1.10 in AP mode, but my DHCP is 192.168.30.x,
How do you set a static IP in AP mode?
WAN and LAN settings are gray out in AP mode, I can't set it.
- Jan 28, 2022Retired_Member
