SonnyKS
Oct 19, 2019Tutor
SRR60 Wireless2 no internet
SRR60 with latest firmware downloaded. Set in AP mode with static IP on LAN. Wireless1 and Wireless2 enabled. Guest SSID disabled. Clients can connect to Wireless1 just fine and access internet...
RaghuHR
Oct 21, 2019NETGEAR Expert
SonnyKS you upload into google drive or any such tool to upload debug logs and send via PM.
Thanks,
Raghu
- evan2Oct 24, 2019NETGEAR Expert
I see the issue using your config, because LAN IP is different from DHCP server,
I restore your config, OrbiPro br0 IP is static 192.168.1.10 in AP mode, but my DHCP is 192.168.30.x,
How do you set a static IP in AP mode?
WAN and LAN settings are gray out in AP mode, I can't set it.
- SonnyKSOct 25, 2019Tutor
evan2 Static IP is set for 192.168.1.10 and DHCP server is at 192.168.1.254
If you take the option to change the setting from Router to AP mode - it lets you set the static IP address and then it grays out the option once it is set in AP mode so you cannot change it unless you do a factory reset.
I have opened a cae with netgear support and they were able to replicate the issue so am awaiting their feedback on what to do next.
- Jan 28, 2022Retired_Member
