BooJangles's avatar
BooJangles
Apprentice
Jun 17, 2020
SRS60 Device Access Control
SRR60 and 7 satellites (5 wired, 2 wireless)
Hi all,
Is it possible to control device access per satellite?
For example, I have a satellite in a basement that has 3 devices physically plugged into it. It has poor signal but is sufficient for the small amounts of data the 3 monitoring devices require. I am trying to prevent a laptop in particular from ever connecting to this satellite.
Is this possible to configure?
Many thanks,
B
  • DaneA's avatar
    DaneA
    Jul 05, 2020
    BooJangles,
    As far as I have check the Orbi Pro user manual here, it seems that there is no option to control device access per satellite.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    BooJangles,
    You may configure a MAC ACL (Access Control List) to prevent the specific laptop to connect to the SSID.  To know how to configure this, kindly read pages 48-53 of the Orbi Pro user manual here
    DaneA
    • BooJangles's avatar
      BooJangles
      Apprentice
      Thanks for that info.
      Is there a way to control device access per satellite instead of the entire network though?
      Thanks
      • DaneA's avatar
        DaneA
        BooJangles,
        DaneA
ProSupport for Business
