jcbick
Mar 02, 2022Aspirant
SRS60 firmware update issue
Hello all. I'm not sure how I screwed up, but i can't seem to get all of my satellites to update to the latest firmware. I've attached a pdf with screen shots. How can I get the router to recog...
- Mar 10, 2022
Trying to login remotely via IP address did not work. Wound up connecting directly to each problem satellite via cable and eventually getting the local page to show and allow the firmware upgrade. Now that they are all the same version, everything is copasetic.
quagmire1
Mar 02, 2022Luminary
You should be able to login to each satellite directly by its IP address. Once in, there is a "Firmware Update" option.
- jcbickMar 10, 2022Aspirant
