dudecs
Dec 02, 2020Aspirant
SRS60 Firmware V2.5.5.100 Failed
Latest firmware for SRR60 V2.5.5.100 installed succesfully. However, corresponding firmware for SRS60 failed to install. Performed this upgrade automatically and manually and both failed. Has anyone ...
- Dec 03, 2020
Yes, I had tried the UI via the web browser and Insight (iPhone app). Both attempted to install and returned with "Install Failed" for the satellite. I checked this morning and the satellite is now updated to the correct version overnight without my intervention. Do not know what happened, but it resolved itself.
RaghuHR
Dec 02, 2020NETGEAR Expert
Hi dudecs
Have you tried with Insight? Could you please clarify what is the error that you are seeing when tried to upgrqade from local UI?
Thanks,
Raghu
- dudecsDec 03, 2020Aspirant
