deets32
Oct 17, 2022Follower
SRS60 no access since firmware update
I carried out a nice little exercise on my Orbi network, naming every device and getting all the admin up to date. I had an issue viewing devices via each satellite as I could only see ‘all devices’ b...
Oct 17, 2022Guru - Experienced User
Make sure that SRS are updated first and using same version of FW that's what's loaded on the SRS unit. All should be using same version of FW.
Factory reset and setup from scratch if problems are seen after a FW update.
