mtc_8's avatar
mtc_8
Follower
Mar 28, 2022
srs60 wire connection
can i mix and match connections? between satelittes router and switch?
i am adding a satellite to my system setup, i got a router srs60 connected directly by with wire to a satellite, and from the srr60 router i got a swtich connected to a free port. my question now from the switch can i connect a satellite? due to the location i like to see if possible to do this
appreciate
thanks.
1 Reply
  • plemans's avatar
    yes you can connect a satellite to the switch. Whenever I use satellites, I'm connecting through a switch.
ProSupport for Business
