Old-Steve
Jul 23, 2022Aspirant
SXK30 ethernet cable between the router and satellite
I bought the netgear Orbi Pro wifi 6 mini router and satellite. I have an ethernet cable running between them but I think they are connected via wifi. I am using ethernet port 4 on the router and e...
Jul 23, 2022Guru - Experienced User
If they're hardwired in together, it should auto-negotiate to use that hardwired backhaul.
If you log in through the browser, what is it showing for the link on the attached devices page?
- Old-SteveJul 23, 2022Aspirant
number 32
towards the bottom
- plemansJul 23, 2022Guru - Experienced User
how exactly is it setup?
Are you going from SXR---->SXS30?
Or is there a switch in between?
Or a modem/gateway device?What firmware is the router and the satellite on?
What does it show if you (temporarily) direct connect the satellite to the router with a short 6ft cable?
Ethernet cable from port 4 on the SXR30 router to port 1 one the SX30 satellite.
No switches in between. Nothing in between. The cable checks good.
Firmware v4.2.0.122
I don't know because the satellite is 50 feet away in my garage.
Do I have to do something to the LAN ports? Configure them so they know there is supposed to be a link there?
