Yonijo's avatar
Yonijo
Tutor
Dec 19, 2017
Orbi Satellite Connection via Ethernet
Hello
I need to connect my orbi satellite in Ethernet wired.
Is it possible now or I have to wait an other firmware ?
Thank you for your help
  • Hello Yonijo
    You will need the to update your Orbi unit to the 2.1 firmware if you check for updates on your unit it should be available to download.
    DarrenM
  • Retired_Member's avatar
    Retired_Member
    each Sat has 3 or 4 ethernet ports.  are you wanting to connect other devices to your sat?
    • Yonijo's avatar
      Yonijo
      Tutor
      Hello
      Thanks for your reply
      I want to connect the two satellites together
      (Not by WiFi)
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Yonijo
        DarrenM
