Old-Steve
Jul 23, 2022Aspirant
SXK30 ethernet cable between the router and satellite
I bought the netgear Orbi Pro wifi 6 mini router and satellite. I have an ethernet cable running between them but I think they are connected via wifi. I am using ethernet port 4 on the router and e...
Old-Steve
number 32
towards the bottom
Jul 23, 2022Guru - Experienced User
how exactly is it setup?
Are you going from SXR---->SXS30?
Or is there a switch in between?
Or a modem/gateway device?
What firmware is the router and the satellite on?
What does it show if you (temporarily) direct connect the satellite to the router with a short 6ft cable?
- Old-SteveJul 23, 2022Aspirant
Ethernet cable from port 4 on the SXR30 router to port 1 one the SX30 satellite.
No switches in between. Nothing in between. The cable checks good.
Firmware v4.2.0.122
I don't know because the satellite is 50 feet away in my garage.
Do I have to do something to the LAN ports? Configure them so they know there is supposed to be a link there?
So I just double checked my ethernet cable. Its good. Its not 50 feet it's 89.1 feet and all the pairs are good. cat5e.
I unplugged my ethernet cable and everything is the same so it is definitely not being used for the backhaul connection.
I plugged it back in and went to VLAN/ Bridge settings in the advanced tab.
Port 4 on the router and port 1 on the satellite both show as not being connected. to anything. But I know the cable is good. I used the same ethernat cable with my last router and wifi extender. And it keeps passing the tests.
Doing some more research... is this a Netgear thing? I bought this router for the VLAN's because I have a lot of IOT devices and I wanted to separate them out on their own network.
But I bought the router on Amazon so I have X amount of days to return it. Good old Amazon.
I was actually torn between this Orb Pro wifi 6 router and the Netgear Nighthawk
NETGEAR Nighthawk 6-Stream AX5400 WiFi 6 Router (RAX50)
I had a R7000 Nighthawk before and I bought the Armor and Bitdefender.
Or this one...
NETGEAR Nighthawk Whole Home Mesh WiFi 6 System (MK62) - AX1800 router with 1 satellite extender, coverage up to 3,000 sq. ft. and 25+ devices
I have until Aug 13 to decide. I realize thats its a little chicken shot to buy things and try them out then return them, but I want what I want and I want it to be right.
Am I over reacting because my backhaul connection isn't hard wired? lol
You tell me...
Are any of these other routers any better? I don't think they have VLAN's built in like the Orbi Pro. I like the Orbi overall.
Now I am confused as all hell and any help and guidance will be greatly appreciated.
Tell me I am over reacting and just shut up and enjoy the internet! lol
Gotta keep smiling!
- plemansJul 23, 2022Guru - Experienced User
Not great at vlans but try port 1 on the router with default and the others with trunk. put the satellite on that port 1
