BrainSuperGlue
Mar 28, 2024Tutor
SXK30 VPN : 0.0.0.0 issue when not using dynamic DNS
Hi, Based in the UK, have a third party DSL router which provides Internet access. This is connected to our SXK30 on its WAN port. All VLANs on the Orbi Pro network can surf the Internet fine. ...
schumaku
Mar 30, 2024Guru - Experienced User
Iuto the OpenVPN config file I had in mind
BrainSuperGlue
Apr 02, 2024Tutor
Sorry, I don't understand what you mean by luto.
Can you clarify?
Thanks.
- schumakuApr 02, 2024Guru - Experienced User
I hsd the OpenVPN config file I had in mind ... typo, sorry
- BrainSuperGlueApr 03, 2024Tutor
So then, the 0.0.0.0 VPN issue still exists.
How can I raise a feature request covering "When DDNS is turned off on Orbi Pro, a place on the VPN configuration webpage to manually enter the external IP address the VPN traffic would be coming from" ?
Thanks
BSG - schumakuApr 03, 2024Guru - Experienced User
