TheGrumpyGent's avatar
Dec 29, 2021
SXK80 - Allow printer on two VLANs?
Is it possible to share a device across VLANs?  In my example, I have a WiFi printer I would like to make available to more than just one VLAN (i.e. allow it on VLAN 1 and VLAN 20).  Is this possible?
  • schumaku's avatar
    schumaku
    Technically this does translate to have IP routing between the subnets, allow the VLAN 20 IP subnet accessible from the VLAN 1 subnet, and last but not least the unknown printer must be discoverable  eg. by the ubiquitous WS-Discovery using Multicast, and for other printer drivers probably other discovery methods (where most like IP broadcast can't work between different IP subnets).
    Netgear released a Beta version -> [In Beta] SXK80 Beta firmware version 3.2.5.778 for mDNS service - however the feature was not made available on newer firmware builds yet. BruceGuo when will this feature become available on production firmware for the SXK80 and the SXK30 Orbi Pro systems?
    • TheGrumpyGent's avatar
      TheGrumpyGent
      Tutor
      Thank you for the details schumaku !  This makes sense;  I'm a bit surprised this wasn't available yet - I know the Orbi Pro has a "reduced functionality set" to support smaller businesses with no IT department, but having a printer etc. available on more than one VLAN is pretty typical.
  • BruceGuo's avatar
    BruceGuo
    NETGEAR Expert
    Hi
    From 4.2.1.112, SXK80 supports mDNS service which allows clients communicate with printer in different VLANs. The feature is located at ADVANCE page. Check it out.
    Bruce
ProSupport for Business
