kc6108's avatar
kc6108
Luminary
Feb 07, 2021
SXK80 2.5Gbe Wired Backhual with Switch in between
I have a need to use a use a switch in between the SXR80 router and SXS80 satellites. Customer wants to use an MS510TX, MS510TXM, or MS4300-16X for the switch. Will multiple VLANS (admin, guest, IoT, and office) work in this scenario? I’m guessing this would be using the satellites in AP mode. The MS510TX(M) switches support IP routing, but being Smart Pro switches lack much of the other managed switch functionalities. What is the best way to use the SXK80B3 mesh product with one of the multi-gig switches? The customer needs >1Gbe LAN connections. Would the M4250-12M2XF be a better multi-gig switch in this use case? Please feel free to be specific on how to connect the products all together. The customer has a CM2000 cable modem that has a 2.5Gbe port. The customer has gigabit Internet connection that is over provisioned to 1.5 gig. I told the customer the SXR80 only has one 2.5Gbe port. The customer is rather upset that it doesn’t have two… one for WAN duties and one for LAN to connect to the satellites. Why hasn’t Netgear added this yet… or at least an SFP+ port or two on the SXR80 and SXS80’s?
Please feel free to suggest other product groupings.
Are there no multi-gig routers with multiple multi-gig ports? Is the SXR80 the only VLAN aware router at Netgear?
  • schumaku's avatar
    schumaku
    So you intend to create a wired backhaul - OK
    Nothing wrong with these ideas. Depends of course on how many wired MultiGig and 10G devices they want to connect to this new wired network enviornment, beyond of the just three Orbi Por 6 devices.
    kc6108 wrote:
    IWill multiple VLANS (admin, guest, IoT, and office) work in this scenario?
    Yes, of course. Needless to say, the VLANs and ports must be configured accordingly, either using the local UIs, or using Insight.
    Well, the wired backhaul can be used with the Orbi Pro WiFi 6 system in router as well as in AP mode.
    Don't think you need inter-VLAN routing initially anyway. What "features" do you think are missing on the Smart Managed Pro switches in general, and specifically on the MS510TXM? When considering any Orbi Pro this is unlikley an enterprise network with the related staff to set-up, maintain, and operate isn't it?
    Yeah, sometimes it's the job for the system integrator to show the limitations and unpopular answers.
    Comes the question for how long the over-provisioning will retain overall - eg. of the ISP does add more bandwidth hungry customers ot the headend for example.
    You might consider configuring a LAG using the two designated LAN ports to the new added switch. For concurrent usage (by more than just one client on the [W]LAN), this would allow to make use of the over-provisioned bandwith. If however the customer is speedtest blinded and unhappy if he does not get this speed on a single computer on the [W]LAN, well.
    Well, nobody ever promised something different - this is well visible as part of the marketing and the product specs, including the Data Sheet.
    Different scope - Orbi Pro WiFi 6 is intended mainly as a throw-in Mesh system, being on a wired or wireless backhaul ... not as a platform for a MultiGit/10G networks.
    Sure these exist, the market is still very niche. Especially where other technology is used, like XGS-PON ... where using own routers is becoming a very difficult thing, and then not allowing seemless IPTV and VoIP ...
    No, however there isn't much beyond their and the BR500/BR200 with plain GbE only.
      • kc6108's avatar
        kc6108
        Luminary
        That is not what I wanted to hear. Maybe the MS510TXM or a fully managed switch would work. I really need to get my hands on a SXK80, MS510TXM/UP, and XSM4316PA/B to fully vet the new Orbi Pro line myself. I have had so many clients asking about the SXK80 along with Netgear's new multi-gig switches. 1Gbe connections just aren't fast enough for some of my clients. 2.5/5Gbe ports are becoming a must feature for a lot of my clients. Netgear's software implementation of LAGs are okay, but not what the client needs a lot of the time.
ProSupport for Business
