raymond008's avatar
raymond008
RBR20 ethernet backhual issue
Hi,
        I am trying to use a mix of 5G + ethernet backhaul setup for rbr20 system. I have 3 rbs20 satellite.
        I use rbr20 as access point mode. All my 3 satellites are working fine now through the 5G backhaul.
        However, when I try to plug in ethernet to one of the satellite, my router seems to get hit by some kind of
        network storm and the cpu usage on my vpn router shoot up to 100%. The connection still show as using 5G wireless.
        Note that I have 2 level of dumb network switches between the rbr20 and rbs20 statellite in that experiment,
        not sure if that makes a difference.
        I saw a youtube video mentioned that the ethernet backhaul connection from the satelliet has to be directly plugged
        into the back of the main unit (i.e. rbr20) without going through a network switch. Can someone confirm that?
        Here is the cofiguration that I am tring to get it to work:
                  ISP -> VPN router -> RBR20 (as wireless access point)  -> 5G backhual -> RBS20 satellite
                                               -> network switch -> ethernet backhaual -> RBS20 satellite
Thanks.
  • plemans's avatar
    What switches is it?
    Also, your diagram with the "+" doesn't say if that switch is plugged into the RBR unit or into your VPN router.
    Make sure its to the RBR unit
    • CrimpOn's avatar
      CrimpOn
      There have been posts describing an "ARP Storm" that sometimes happens when satellites are connected through a dumb switch.  Apparently the storm continues for a minute or two and then ceases.
      Does the Orbi stay at 100% CPU for an extended length of time?
      • raymond008's avatar
        raymond008
        The 100% cpu is on my VPN router (tl-r600vpn), not the orbi unit. It situated the CPU and ended up knock out my network access until I unplug the satellite. I don't think it's related to the rbr20 unit at all ...
        Here is my detail setup and connectivities:
        ISP -> WAN -> tl-r600vpn -+- LanPort1 --> rbr20 -> 5G backhaul -> rbs20 (x2)
                                                 -+- LanPort2 --> tl-sg1024s -+-> gs724t -+-> tl-sg116 -+-> rbs20 (also connected through 5G backhaul at the time)
        All my orbi units including rbr20 are on dhcp (i.e. dynamic IP assigned from the VPN router).
        As you can see, I try to connect the main unit (rbr20) through multiple layer of switches to satellites.
        I try to get a confirmatioin that will the above configuration works or not. Or I have to connect the tl-sg1024s
        into the lan port of rbr20.
        I wonder if I need to remove the satellite before I re-connect it through ethernet to avoid the ARP storm issue probably triggered by the dual path to the main unit. I haven't tried that yet ...
        Thanks.
      raymond008
      Is that the only way it will work?
      The reason I try not to plug the switch to the rbr20 unit is try to avoid the wireless AP
      bring down the entire network including the wired devices, e.g., during wifi reconfiguration.
      Thanks.
