blunderdome85
Oct 15, 2021Apprentice
SXK80 3.3.0.122 Fast Roaming Option Gone
Just decided to try the new 3.3.0.122 firmware and noticed that the option to enable/disable fast roaming under Advanced Setup -> Wireless Settings is gone. Factory reset after the update and confir...
- Mar 01, 2022
New firmware V4.0.0.118 is now out for the SXK80 and the Fast Roaming Option is back!
