blunderdome85
Oct 15, 2021Apprentice
SXK80 3.3.0.122 Fast Roaming Option Gone
Just decided to try the new 3.3.0.122 firmware and noticed that the option to enable/disable fast roaming under Advanced Setup -> Wireless Settings is gone. Factory reset after the update and confir...
- Mar 01, 2022
New firmware V4.0.0.118 is now out for the SXK80 and the Fast Roaming Option is back!
blunderdome85
I'm still on 3.2.6 for the moment - can anyone on 3.3.0 check to see if they just moved it to the debug page?
- quagmire1Oct 15, 2021Luminary
Way ahead of you - I already checked that. It is *not* on the debug page.
- blunderdome85Oct 17, 2021Apprentice
Did some testing over the weekend and it looks like fast roaming is on with no way to disable it via the GUI. I for one need the option to turn it off restored as fast roaming is too agressive for some of my IoT devices.
- blunderdome85Oct 22, 2021Apprentice
Got a PM from DavidGo earlier this week saying they would check on this and get back to me ASAP but nothing since. I would think this is a pretty straightforward, "Oops, we made a mistake" or "Yes, we intentionally removed a feature". Can we get an official response, please?
