Architekt
Jun 15, 2021Apprentice
SXK80 AP Mode: Disable captive portal on "Guest Portal" wifi
I have wireless 1/2/3 set up working great. I would like to use the "Guest Portal" wifi as just another wireless SSID. However I cannot see any way to disable to captive portal option. There's no che...
Architekt
I don't know why uploading an image doesn't seem to be working. Also I can't edit my post anymore. Let's see if attaching it as a file works...
- schumakuJun 16, 2021Guru - Experienced User
Architekt wrote:I don't know why uploading an image doesn't seem to be working.
Perfectly normal - in-line images are under mandatory moderation.
The guest network is predefined by design with a captive portal, it's not a freely configurable "Wireless 4" unfortunately.
