ghstudio
Apr 25, 2023Apprentice
SXK/SXS30 connected devices - doesnt show all connected devices (error report)
I have an #SXR30 (Orbi Pro mini) with one #SXS30 satellite using a wired backhaul. There is one computer connected to the SXKS30 with an ethernet cable and it's running at full speed (500/500). ...
Apr 25, 2023Guru - Experienced User
Does it show up if you log into the SRS30's gui? It should show connected devices there.
ghstudio
yes...it shows as wired on the satellite.....but it should also show on the router just as the wireless devices on the satellite show on the router. It's a design issue....one should not have to go to each satellite to see all of the devices on the network....especially since the wired devices on the satellite get their addresses (including static addresses) from the router.
