ghstudio
Apr 25, 2023Apprentice
SXK/SXS30 connected devices - doesnt show all connected devices (error report)
I have an #SXR30 (Orbi Pro mini) with one #SXS30 satellite using a wired backhaul. There is one computer connected to the SXKS30 with an ethernet cable and it's running at full speed (500/500). ...
Apr 26, 2023Guru - Experienced User
You're correct. I wasn't trying to argue that part. Was just curious if the satellite was showing them connected.
What firmware is on the router and the satellite?
What modem/gateway is the router connected to?
ghstudio
Apr 26, 2023Apprentice
4.2.3.102 on both connected to FOX222 Frontier ONT. For completeness, everything is running over MOCA 2.5 adapters on existing coax which works flawlessly using the Frontier provided NVG468mq
- plemansApr 26, 2023Guru - Experienced User
So you've got the SXR connected to the NVG (the fontier gateway). And then you're using the NVG's moca adapters to connect the satellites?
If so, that'd be your issue.Right now, you'r using 2 routers and are in a double nat.
The satellites should be connected to the SXR's lan port. If its connected back through the NVG router, its not going to show up properly as its not setup in the correct fashion.
Options? If its working fine other than not displaying correctly, you could leave it.
Otherwise if you're wanting hardwired backhaul, you'd need to go
NVG--->SXR wan port---->SXRlan ports----->satellites
and you wouldn't be able to use the moca capability of the nvg.
You'd have to use ethernet.
Or you could use the wireless backhaul capability of the satellites (which would be slower than hardwired).
You're a little caught because of your cascading routers with the satellites behind the nvg and not the SXR
