whatever11's avatar
whatever11
Initiate
Jun 21, 2023
SXR-80 No longer to access 1 SSID for some devices
I have been using my Orbi for years in the same location, same network and no new devices added for months.  I had to reboot the router and now many of my IoT devices can no longer connect to the IoT vlan.
I have 4 SSIDs with Guest not currently enabled. I did separate the IoT SSID into 2 IDs for the 2.4 v 5 g to get IoT onto the network.
Again, no changes. I did have an issue in January with network but changed the channels and that fixed it. I have not made any changes for months, besides the channel change.
After the reboot some of the IoT devices were re-connnected, others were not (iPhone can't get into the network, some power outlets and switches ie Kasa Smart outlets. Some are back on, some not. Wyze bulbs and outlets reconnected, Amazon Echos cannot).
I see no pattern on this,
Settings are Access Control off (ie anything can join). These are 're-joining' devices.  Password is valid and correct.  I did change the channel for 2.4 yesterday, no impact.  I have rebooted several times, no impact.
I only run the basic/out of the box set up. I have the SSIDs, using the 10-20-30 settings.  The IoT does not work (30) but the main one does (TV is on as well as PC and they stream).  I am running latest firmware. Have 1 router and 2 satellites.  Worked for all of these devices until reboot on Monday.
No idea how to fix this
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello whatever11 ,
    I understand that there has been no change in network configurations prior to your reboot on Monday. Please remove/forget the network for the IoT devices that failed to connect, then install them back on the network.
    Best,
    Kevin
    Community Team
    • whatever11's avatar
      whatever11
      Initiate
      I rebooted the router 4-5 times and it fixed it. Clearly reboot (both with power off and through Insight) does not clean the cache/data as well as it should
      It works now
ProSupport for Business
