MiloDV
Oct 12, 2022Aspirant
SXR30 & WAX610 - VLANs & SSIDs
Hi Relative newbie who has inherited a router issue, so help would be very much appreciated. In the absents of a replacement for our BR200, I have read on the forums that you can use a SXR30. H...
JeraldM
Oct 13, 2022NETGEAR Employee Retired
Welcome to the community!
The SXK30 does come with presets for VLANs and SSIDs in which you can modify based on your preferred network setup (please see page 74 of the user manual here regarding how VLANs work on the Orbi Pros).
JeraldM
NETGEAR Community Team
MiloDV
Oct 13, 2022Aspirant
Many thanks Jerald & for the warm welcome.
Oh, ok. So if I’m understanding this correctly:
1) If I disable Wi-Fi on the SKR30, I can use all 6 existing SSIDs & corresponding VLANs in the LAN through the GC728X & 2no. WAX610.
2) However, when it comes to internet access, I can't just plug a trunk cable into a SKR30.
3) There aren’t enough ports on a SKR30 for all 6 VLANs
4) So, I would have to maybe configure one additional VLAN to 'access' between the SKR30 & GC728X & allow all the other VLANs to access it in order to be able to reach the internet?
Or
Does Netgear not do an Insight Router capable of 802.1Q?
