NickF8
Jan 24, 2025Aspirant
SXR30 and orbilogin.com
Hi, I am hoping someone can shed some light on an issue I had yesterday when trying to login to my Orbi. I had some internet issues and wanted to check the config had not reset itself as I have had...
Jan 24, 2025Guru - Experienced User
Try the routers IP address in the browsers.
Be sure to clear out all browser caches before going to the routers web page.
Does FireFox work for the windows PC?
Try a different Windows PC to see if problem follows.
- NickF8Jan 24, 2025Aspirant
Thanks - didn't try Firefox.. but will give that a go in the future.
I did use 2 different Windows PCs and builds, both with Chrome and Edge before getting the Mac out.
I got the same response from the IP Address.. I get the cert error, then safe to visit and then the same error as the url.
