cpolizzi
Nov 20, 2024Aspirant
SXR30 and Verizon FIOS
I am trying to replace the CR100B Verizon Router with an SXR30 Router and 1 satellite. I have reset the router to factory settings and it ended with a solid white light. I connected to the router u...
- Nov 25, 2024
I spent 2 hours in a chat with Verizon and they were no help whatsoever. They would not answer a question as basic as, "Do you support 34d party routers in place of your own equipment?"
However, I did finally find the attached document. It appears that the ODN holds onto the IP address lease for their modem blocking attempts to replace their router. By issuing a command to release the IP address on the Verizon router and immediately unplugging it, I could then install the SXR30 with no issues.
Note that the document is from Verizon. All they kept saying was they didn't recommend 3rd party devices as they had a bunch of value added features that they could not elaborate on.
The Verizon solution was to replace the router with an older version (a CR1000A instead of CR1000B) and add 2 network extenders of their own. The newer router my son already had would have to be hardwired to the extenders while the older one could work wirelessly.
Nov 20, 2024Guru - Experienced User
Something to ask the ISP about. Ask them about any special WAN side configurations or if the ISP gateway is required or can be replaced.
CrimpOn
When I search for Verizon CR100B, the only hits appear to be for a CR1000B
- cpolizziNov 20, 2024Aspirant
Yes. Sorry. I dropped a 0. It is a CR1000B
- CrimpOnNov 20, 2024Guru - Experienced User
Very strange. I cannot find any mention in the CR1000B User Manual of putting the device into 'bridge' or 'passthrough' mode. This article mentions outright replacement using exactly the method you describe:
https://www.reddit.com/r/Fios/comments/1d9wv5o/need_help_getting_rid_of_cr1000_fios_router_and/
